ICD3 and FC7
Speed64
Has thanked: 4 times
Been thanked: 2 times
ICD3 and FC7
Post by Speed64 »
I want to set up ICD 3 in FC7.
what is in "location"?
what is written in the "parameter"?
Many thanks in advance
Re: ICD3 and FC7
This may help, but is a bit old:
http://www.matrixtsl.com/faq/index.php? ... light=icd3
There's also information here:
http://www.matrixtsl.com/wikiv7/index.p ... _.28NEW.29
You should also be able to use the "ipecmd.exe" tool to program the ICD3, but I don't know the correct command line parameters.
Speed64
Re: ICD3 and FC7
Post by Speed64 »
Thank you, it does not work.
I use Windows 10 (64 bit)
I have MPLAB v3.35 installed.
The IPE window does not start.
Speed64
Re: ICD3 and FC7
Post by Speed64 »
I get an error message.
C: \ Program Files (x86) \ Microchip \ MPLABX \ v3.30 \ mplab_ipe \ ipecmd.exe reported error code -1
howard123
Has thanked: 30 times
Been thanked: 28 times
Re: ICD3 and FC7
Post by howard123 »
Hi. Could it possibly be that your path has 'V3.30' and you have V3.35 installed.
Re: ICD3 and FC7
Hi Speed64,
Any joy with this? If not then what programmer settings are you using and we will double check them for you.
Speed64
Re: ICD3 and FC7
Post by Speed64 »
Hellow:
When I start the programmer manually following is specified as the destination.
"C:\Program Files (x86)\Microchip\MPLABX\v3.35\sys\java\jre1.8.0_91\bin\javaw.exe" -jar "C:\Program Files (x86)\Microchip\MPLABX\v3.35/mplab_ipe/ipe.jar"
Running in:
"C:\Program Files (x86)\Microchip\MPLABX\v3.35\sys\java\jre1.8.0_91\bin"
without parameters
