HI
Just a quick question
Can the XC compiler in FC be updated by downloading the newer version from Microchip and over installing?
FC7 Compiler
- Has thanked: 553 times
- Been thanked: 1081 times
Re: FC7 Compiler
A newer version can be installed in a separate folder and pointed to in the compiler settings window, however changing the compiler may break things due to changes in the compiler. Overwriting the original compiler in the Flowcode 7 folders is not a good idea as it will break the uninstaller.
― C.S. Lewis
― C.S. Lewis
Re: FC7 Compiler
I have successfully set up Flowcode so it works with the latest XC8 version:
I have tried both methods i.e changing compiler settings and overwriting files and both work.
I agree with kersing that changing compiler settings to a a separately installed compiler will be best.
If you need help then I can assist you further.
http://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Microchip\xc8\v1.38\bin\xc8.exe --chip=16F1937 "StopWatch.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.38
Build date: Jun 30 2016
Part Support Version: 1.38
Copyright (C) 2016 Microchip Technology Inc.
C:\Program Files (x86)\Flowcode 7\CAL\internals.c: 72: (1090) variable "_FCI_TMP_INT" is not used (warning)
C:\Program Files (x86)\Flowcode 7\CAL\internals.c: 71: (1090) variable "_FCI_TMP_STR" is not used (warning)
Memory Summary:
Program space used 426h ( 1062) of 2000h words ( 13.0%)
Data space used 35h ( 53) of 200h bytes ( 10.4%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Data stack space used 0h ( 0) of 1CBh bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
C:\Program Files (x86)\Flowcode 7\tools\DoNothing\DoNothing.exe
FINISHED
