OR operator not working? [resolved]
Camusensei
Post by Camusensei »
Hello, I need to see an application exaple for the "OR" operator...
In an IF function, I tried :
touche = 1 OR touche = 2 OR touche = 3 OR touche = 4
(was only true if touche = 4)
and
touche = 1 OR 2 OR 3 OR 4
(was always true)
Perhaps I am not correctly using the "or" operator?
please tell me how to use it!
and I would also like to know if it would work if I tried :
0<touche<5
or
1<=touche<=5
thank you in advance
ALAN_26
Post by ALAN_26 »
HELLO Camusensei
TRY THIS SHULD WORK FINE ON FLOWCODE V3 ONLY !
(touche = 1) OR ( touche = 2) OR (touche = 3) OR ( touche = 4 )
Camusensei
OH, thank you very much!
I'll try it tomorow and I'll tell you!
see ya!
emad
Post by emad »
HELLO Camusensei
If you mean that the variable touche has a value between 0 & 5 then the next code will work fine
IF ( touche >= 0 ) && ( touche <= 5 )
To add to this, the words "OR" and "AND" are "bitwise" operators (equivalent to the 'C' & and | operators). This was the case in Flowcode v2 and was retained in v3 for backwards compatibility.
In v3, we introduced "logical" operators - these are && and || (the same as in 'C').
Both Alan's and Emad's suggestions should work.
Camusensei
OK, I tried the first method working fine and I'll use the second I have to use it^^
Thank you very much all of you!
