hi,
i am planning to implement capacitive touch sensing using only ADC pin.
anybody has done this?
how can i implement this in flowcode?
Re: capacitive touch sensing using only ADC pin
In Flowcode 6 and 7 there are components (touch pads / touch slider) to allow you to do this.
There's also loads of info already on the forums about how to create your own cap touch code. Just use the search feature and use the keywords cap touch.
HELLO BEN,
as per your suggestion, i went through a search with keyword CAP TOUCH and i found a thread where you only have mentioned that in FC5 there is a option called 'ADC raw'.
i would like to know how that works for cap touch. or do you have any example that uses adc raw feature?
thanks and Regards,
Prashant
thanks and Regards,
Prashant
Hi Prashant, any luck getting Ccap touch to work?prasha920 wrote:HELLO BEN,
thanks and Regards,
Prashant
You tried the Bathmate X30 http://bathmatex30.com/ yet?
Hi Guys,
Have you seen this thread?
If you scroll down on the thread there are more examples.
hi Spilled,
i'm sorry for late reply..
as i didn't had much time to work upon those examples, i couldn't tried it.
as soon as i work on those examples with hardware, surely will update you guys..
thanks and regards,
Prashant
thanks and regards,
Prashant
Thanks Prashant,
Good luck with the testing.
