Number TO Hex
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
Alan_37
Has thanked: 51 times
Been thanked: 54 times
Number TO Hex
Post by Alan_37 »
Just found a small bug , when converting Number to hex string
for 1 to 9 in the simulation shows that hex string is 0x01 to 0x09
but than when you burn to the chip the string is 0x1 to 0x9 , it took me while
trying to find what is wrong cause i was comparing the
Hex string to another string , in simulation worked perfectly but on chip
dose not .
Chip is : Atmega2560 ( Arduino Mega2560 R3)
So hope you can fix it thanks .
Alan
Re: Number TO Hex
Hi Alan,While you are waiting for that to be sorted, have you see this?
Re: Number TO Hex
Please can you try this updated CAL file and see if it solves the problem for you. It should now force the number to have at least two characters e.g. "0x01" instead of "0x1"
The file needs to be placed into the "Flowcode 7/CAL/AVR" directory before recompiling your project.
AVR_CAL_String.c
(23.5 KiB) Downloaded 584 times
Alan_37
Re: Number TO Hex
Post by Alan_37 »
Hi Benj
Just saw the post to day ,
I have fixed the problem by cutting the 0x then check the string length if = 1 then hex_string = "0" + hex_string .
But i will certainly replace the cal file make some test and let you know .
Thanks very much .
Alan
Alan_37
Re: Number TO Hex
Post by Alan_37 »
Hi Benj
Just made the test, i think this needs some more attention see Attachment :| .
(26.51 KiB) Downloaded 7396 times
Alan_37
Re: Number TO Hex
Post by Alan_37 »
I have overwritten the original file , can someone upload AVR_CAL_String.c please
Thanks in advance .
Re: Number TO Hex
Hopefully this will help.
AVR_CAL_UART.c
(61.94 KiB) Downloaded 566 times
Alan_37
Re: Number TO Hex
Post by Alan_37 »
Thanks medelec
But still no luck
Re: Number TO Hex
Hi Alan,
i have posted the original file as requested.
Not modified it at all.
Has thanked: 481 times
Been thanked: 699 times
Re: Number TO Hex
Hi Alan,
Try this ..
AVR_CAL_String.c
(23.57 KiB) Downloaded 601 times
Alan_37
Re: Number TO Hex
Post by Alan_37 »
Hi Leigh
Yesss that Fixed it , please include this in the update .
Thanks very much .
Alan
(10.88 KiB) Downloaded 7306 times
Re: Number TO Hex
Hi Alan,
Thanks for the confirmation, the file is now in our repo ready for next update/release.
Leigh
