Multi threading
For Formula AllCode users to discuss projects, programs, and any other issues related to the Formula AllCode robotics platform.
mark_harrison
Multi threading
Post by mark_harrison »
Hi all - just starting to get to grips with Formula Allcode through VB and connecting to the robot via Bluetooth.
Does anybody know if it's possible to multithread? For example to have a siren sounding as the robot moves? I've given it a whirl but it doesn't seem to like it.
Mark
Re: Multi threading
Hi Mark,
You should be able to use the SetMotors function and then call the PlayNote function while the robot is moving. The SetMotors function does not use encoder feedback and so will immediately return allowing you to call other functions.
Note that using SetMotors if using speeds below 20 the motor may not start or may be less balanced as it just controls the PWM signals to the motors.
mark_harrison
Re: Multi threading
Thanks Benj
What's the tactic for getting more than one robot to 'dance' in time with another? If you can't multithread then how do you send simultaneous commands to the different ports? Or would you have to run the code from an SD card and sync them by pressing a button on them all at the same time?
cheers
Mark
Re: Multi threading
Hi Mark,
Getting multiple robots to dance together is usually a case of giving each robot a command at high speed. Usually this is enough to make it appear that the robots are exactly in sync even though there could be a few nano/micro/milliseconds between each robot. As you can send out commands at high speed but generally the robot is moving for seconds the illusion of dancing in sync should be easy to achieve.
e.g.
FA1 = OpenCom (0)
FA2 = OpenCom (1)
FA1.SetMotors(50, 50)
FA2.SetMotors(50, 50)
Delay 1 Second
FA1.SetMotors(-50, 50)
FA2.SetMotors(-50, 50)
Delay 1 Second
Your method of storing commands on an SD card and pressing each switch at the same time would also work but in manually pressing the switch you will likely incur larger delays then using the API method.
