[Resolved] BUG 16F1824 External Vref+ not working.
Attached is a very basic flowchart to test external Vref+
If using EB006 then connect:
POT (AN3) to A6
Vref (A1)Voltage to B6
LCD Port C (C0 to C5)
All working as expected with FC5 and below
Not working with FC6 and FC7
POT (AN3) to A6
- 16F1825 Vref Test_v7.fcfx
- (8.18 KiB) Downloaded 304 times
- 16F1825 Vref Test.fcf
- (9 KiB) Downloaded 311 times
Re: BUG 16F1824 External Vref+ not working.
Looks like bits 0 & 1 of not being assigned correctly.
I can get it working by modifying PIC_CAL_ADC.c
to:
But that does not sort out FVR
I'm guessing Vref = 1 is the value of selection?
So if Vref = 1 then external Vref is selected.
Vref = 0 then internal Vref is selected.
Vref = 2 then FVR is selected?
I could be totally wrong?
So this will probably not work:
Out of curiosity, how can I modify what code does depending on selection?
For example if VDD do a, or Vref+ do b or FVR is selected do c etc.
As it does nor appear to be Vref = 0, Vref = 1 or Vref = 2.
Edit: Going down the wrong lines since if use
Then external Vref is used on all ADC components even if VDD is selected.
So had to use if so only ADC component that has Vref+ will use external Vref.
ADCON1: A/D CONTROL REGISTER 1 I can get it working by modifying PIC_CAL_ADC.c
to:
if (Vref = 1){ //assign VREF functionality
ADCON1 = ADCON1 | 0x02;
} I'm guessing Vref = 1 is the value of selection?
ADCON1 = ADCON1 | 0x02; //Select Vref+
else
if (Vref = 2){ //assign VREF functionality
ADCON1 = ADCON1 | (Vref & 0x03); //Mod to allow FVR as VREF
FVRCON=FVRCON | 0xC1; }For example if VDD do a, or Vref+ do b or FVR is selected do c etc.
if (Vref = 1)So had to use if
(Vref != 0)Martin
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Hi Martin,
Thanks for your work on this, please try the attached.
Thanks,
Leigh
ps. btw, some of your problems are down to that "easy to do in C" typo
Thanks,
Leigh
which will set Vref to 1 and always be true, should be (but I'm guessing you know already!)...if (Vref = 1)
if (Vref == 1)
- PIC_CAL_ADC.c
- (105.08 KiB) Downloaded 298 times
Hi Leigh,
Thanks for the update.
All three selections are working like a charm.
Thank you.
Ah yes I was assigning rather than comparing.LeighM wrote:ps. btw, some of your problems are down to that "easy to do in C" typo
Thank you.
- Has thanked: 1135 times
- Been thanked: 299 times
Hi Both!
This new cal file, is this for FC 6 and FC7
Please
Br
Jorgen
Br
Jorgen
Hi Jorgen,
So I have attached an unofficial V6 version that's copied from LeighM Fix.
No it can't be for both V6 and V7 since V6 uses Boost C compiler (uses lower case register names) and V7 uses XC8 compiler (uses upper case register names).jgu1 wrote:This new cal file, is this for FC 6 and FC7 Please
- PIC_CAL_ADC.c
- (99.05 KiB) Downloaded 312 times
Your welcome Jorgen.
I did say based but have changed it to copied as it was just a direct copy of Leighs code.
So Leigh should have all the credit for that one.
Re: [Resolved] BUG 16F1824 External Vref+ not working.
Hi Martin!
I have played a little with your example with Vref. In test (simulation) before and after update. I see the same result before and after update. Maybe it only work in real world.
I see when I turn the pot from 0 to max. in display 0 - 1023 ok Int. But as I understand by using the Vref. in your example "Vref 250 Then I should see in the display 1023 when the pot is half "speed" (ajd. to 2.5V) but it is still 1023 by max after. Hope you understand my question. Or do I misunderstand concerning the use of Vref.
Br
Jorgen
Br
Jorgen
Hi Jorgen,
You will only see a difference with hardware, but you are getting the concept correct.
If you look at the datasheeet for 16F1825 you will see that ADCON1 register controls ADPREF (Analogue to Digital Positive REFerence voltage) bit.
On page 149 shows a switch controlled by ADPREF.
As its internal to 16F1825 the simulator won't show the difference between VDD and +REF unless you are using GetVoltage or GetString.
In those cases the VREF+ within properties will take effect.
If using VREF+ then you need to set a fixed voltage at the VREF+ pin by using two resistors as and example.
So VREF+ may not be +2.5V if two resistors are not identical values.
Hi Martin!
Thank you for your explanation, Then I understand it correct. I Will test it in Real " world " this weekend. I have never used Vref before.
Thank's
Br Jorgen
Thank's
Br Jorgen
Hi Jorgen,
At the time of writing, the following only applies to:
You have three Vref options to choose from:
VDD - This uses the microcontroller supply voltage as a reference.
The resolution for Byte (8 bit) = 5/256 = 19.53mV (so for every increase in voltage by 19.53mV, ADC value increases by 1)
The resolution for Int (10 bit) = 5/1024 = 4.88mV
VRef+ - This uses the microcontroller external pin for the voltage reference.
So if two resistors connected set the voltage on external pin to 2.5V.
The resolution for Byte (8 bit) = 2.5/256 = 9.77mV
The resolution for Int (10 bit) = 2.5/1024 = 2.44mV
FVR (Fixed Reference Voltage).
This uses an accurate internal voltage.
The default for Flowcode has set this voltage to 1.024V
The resolution for Byte (8 bit) = 1.024/256 = 4mV
The resolution for Int (10 bit) = 1.024/1024 = 1mV
It's the 1mV resolution which makes this setting very useful indeed!
For Example see this post.
Note: By changing values of within FVR can be
12F1822, 16F1823, 16F1824, 16F1825, 16F1828, 16F1829VDD - This uses the microcontroller supply voltage as a reference.
FVRCONCode: Select all
PIC_CAL_ADC.cCode: Select all
1.024V, 2.048V & 4.096VMartin
Hi again Martin!
Again thank´s for your great and big explanation. I will order a 16F18xx (have no in my stock) and make a test.
Best regard Jorgen
Best regard Jorgen
No Problem.
18f1825 for example are cheap chips with loads of rom and functions.
By the way a small typo.
i posted
The resolution for Int.
Now corrected text.
i posted
When it should of statedmedelec35 wrote:The resolution for Byte (10 bit)
Now corrected text.
