Back in August I raised this problem in one of my previous Posts.
I though MATRIX would have fixed this bug by now, but it seems that the ICD+gost tec does not work with MIAC V2.
The result is that I cannot debug the software I wrote for a switching gas system and I have to deal with the disappointment of my Customer.
Do you have a solution for me, please?
Giovanni
MIAC ICD debugging kit don't work with MIAC V2
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: MIAC ICD debugging kit don't work with MIAC V2
As I recall, we found and fixed a bug in Flowcode, relating to ICD markers at the end of macros.
I will need to check on Monday if this got ported back into V6.
Leigh
Leigh
- LeighM
Hi Giovanni,
The ICD issue has now been fixed in V6, as well as V7.
This ICD bug was associated with macros that return values.
The updated Flowcode V6, which is version 6.1.4, should be available on our servers later today.
Please use the “Check for Updates” feature to upgrade your installation.
Best regards,
Leigh
Best regards,
Leigh
- Been thanked: 18 times
Hi Leigh,
I did a “Check for Updates” this afternoon (14/11/16), and it reports that my current version 6.1.3 is up to date !
Stewart
Stewart
- LeighM
Hi Stewart,
Thanks for the note, looks like the update isn't quite there yet, we'll look into it.
Meanwhile, please try these direct links.
Full installer: http://www.matrixtsl.com/accounts/files ... .1.4.0.msi
Patch update: http://www.matrixtsl.com/accounts/files ... .1.4.0.exe
Leigh
Leigh
