Usb slave pic24 & fc7
Just for information, I have check my small program with FC7 and... same as FC6
, it doesn't work and i have no access to the source code of usb functions, if somebody had an idea...
- test_v7.fcfx
- (9.45 KiB) Downloaded 245 times
Re: Usb slave pic24 & fc7
No it's not a config problem (you havn't check my prog on hardware
), to give proof of that I am sending you a program that works well. The problem seems coming from the UsbSlave_CheckRx procedure (i rewrote it)....
- test_usb_v6.fcfx
- made with FC6 but the same with FC7
- (11.26 KiB) Downloaded 252 times
