If update V6 to latest version (6.1.4.0 at the time of posting) then PWM fix posted here is undone.
PWM will no longer work after update.
BUG PWM
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: BUG PWM
Hi Leigh,
Please make it 6.1.4.1 if you release a new build to avoid confusion... (are you running 6.1.4.0 downloaded before or afer...)
― C.S. Lewis
― C.S. Lewis
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: BUG PWM
Does not look like there is any immediate plan to re-release.
(The guys are busy with V7, and V6 build releases are a major headache)
Apparently the 6.1.4 was an exe update only on the previous release, for the Ghost issue only, so does not have any component or CAL fixes since.
Hopefully the forum post with the PWM fix will suffice for now.
Thanks!
Leigh
Thanks!
Leigh
- Has thanked: 1135 times
- Been thanked: 299 times
Re: BUG PWM
Hi all!
Does I understand that I have to overwrite this "old" file again to be able to use PWM in this pic again
Please, why does MM not save all the corrected bugs after correction and then include them when a new update is release
. As I understand we have to overwrite all the corrected bugs since 6.1.3 in the new 6.1.4
Suddently we discover new release and nobody inform that we have overwrite all fixes again or save the lib. In my opinion, an update include ALL corrected fix.
Please is it not possible to get a new release "6.1.5" with all fixed bugs, a totally update. I use lot of time to keep control all these good or bad file and overwrite new file.
Please please MM..
Best regard Jorgen
Please please MM..
Best regard Jorgen
