Hi I have some trouble getting text on more than 2 lines on these 4x20 OLED screens. on both Winstar and RayStar 4x20 displays whit WS0010 controller.
If I use LCD 4x20 (Adafruit, OLED) component
I get the following error:
Line 1 comes on line 1 (as it should)
Line 2 coming on line 2 (as it should)
Line 3 coming on line 2
Line 4 comes on line 2
If I use LCD (Generic) component
Line 2 is not displayed
Line 3 coming on line 3 (as it should)
Line 4 is not displayed
this problem is just on OLED displays and not on standard crystal LCDs
Link til fc6 test project
https://dl.dropboxusercontent.com/u/209 ... _test.fcfx
Link til Display
http://www.tme.eu/en/details/rec002004a ... pp5n00000/
Anybody know what I'm doing wrong?
I use Arduino Mega 2560 and connects the display in 4 bit mode
Winstar and RayStar OLED 2004A whit WS0010 controller
- Been thanked: 14 times
Re: Winstar and RayStar OLED 2004A whit WS0010 controller
Is there no one who knows anything about this?
Kenneth
Kenneth
I've not played with these displays so not aware of this issue. If you just stream out data to the display. e.g. keep sending out 'x' characters starting from 0,0 then do all the displays characters fill in or are there parts that never get a character?
If you eventually get 'x' characters everywhere then it's an addressing issue and we need to find out the right addresses for the characters.
If you don't eventually get characters everywhere then the display is doing something fundamentally different and we would need to investigate this.
Looking at the device datasheets it looks like the memory should be laid out as expected though they only show the memory layout for a 2-line display.
Aha just found this which looks interesting.
Try using the cursor command with Y as 0 and X as the hex value shown in the image to move to the start of a line.
The decimal addresses would be
Line0 - 0
Line1 - 64
Line2 - 20
Line3 - 84
Line0 - 0
Line1 - 64
Line2 - 20
Line3 - 84
yes Benj you are the king
. The table worked perfectly on Adafurit components. Moving corsor in X and not Y worked perfectly.
I have a small isju with these:
every time I send the program over to the Arduino I must disconnect the power completely on it. Otherwise the display will not work properly (just lots of unreadable characters).
Is this something we can fix? not so serious but quite annoying
