Hi all,
I have modified the example program to generate a letter on the PC screen, have not tested it as I do not have the ECIO-40 module. Which is the smallest and most simplest of PIC's I can use with this USB_HID component to generate a single letter on the screen of a PC when a button is pressed? The second question is: can one send this data via any output pin on the pic? The USB has a Data + and a Data- connection, how does one connect this to the PIC that is used?
As I have never used this component before, I would really appreciate some help.
Ted
USB HID Keyboard
Re: USB HID Keyboard
Hi Ted,
It's been a while since I looked at these, I believe the 18F14K50 is quite cheap and supports USB, the 18F24K50 might also be a good one.
The USB enabled chips have dedicated D+ and D- pins when using the USB functionality.
There are some 16F USB enabled devices now but I haven't personally played with these so don't know for sure that they will work.
The ECIO device will save you the pain of configuration settings etc and wiring up, e.g. it will simply work.
Thanks for the help, it is greatly appreciated. The reason that I am not using the ECIO-40 module is because I need to incorporate this design into another project for a customer, so I need to keep size and price to a minimum.
Will get hold of a few samples of the PIC18F14K50 chip and try the program out with it, I see that FC6 does support this chip.
The chip does not have a function in the configure section where one can select an external or internal clock, so I take it that it is automatically set for internal clock? What should the clock speed be set at for USB operation?
Many thanks
Ted
Many thanks
Ted
Hi Ted,
The project clock speed needs to be set to 48000000.
You can use the internal oscillator or you can use an external crystal. I'd recommend a 12MHz crystal and the config settings as shown below.
