Compile AVR to BIN
jimha
Compile AVR to BIN
Post by jimha »
How can I compile my AVR (Xmega32A4) to BIN format?
Thanks!
Re: Compile AVR to BIN
You can try replacing the file in the "Flowcode 7\compilers\avr\batchfiles" folder with the attached file. This should generate an additional .bin file for you when you compile.
avrb.bat
(666 Bytes) Downloaded 270 times
Please note the file produced will be a ProjectName.cof.bin mainly because I have hacked it in there. If the .cof causes any problems then it might need to be manually removed from the file name.
jimha
Post by jimha »
It works w/ Thanks!
MarekRS2
Post by MarekRS2 »
Hello, can I compile .bin file for PIC 8bit MCU?
