I purchased one of these from SparkFun. The interface pin connections are here on page 3 of the following link.
<https://www.sparkfun.com/datasheets/LCD/GDM12864H.pdf>
I also found a FC v6 example, using the gLCD_KS0108. In the example, there is a RS connection and a Reset connection. What is the difference? I am having trouble reconciling the connections between the FC example and the data sheet for the above listed connections.
Is there clarification? I have included a screenshot for the FC example.
Thanks in advance.
gLCD_KS0108
Re: gLCD_KS0108
RS is register select, sometimes referred to as A0 or CD (Command/Data).
In your case it looks like the D/I pin. Not seen it called that before
- Has thanked: 23 times
- Been thanked: 16 times
Re: gLCD_KS0108
Thanks. Was I correct in updating the gLCD_KS0108.fcpx file as listed below? For FC_V6. I have the old one.
http://www.matrixtsl.com/mmforums/viewt ... 108#p77594
Re: gLCD_KS0108
Yes that shouldn't cause any problems and will allow you to use the new type displays with 3 CS pins as well as the older style with only 1 or 2.
