Calculatino problems
kennethnilsen69
Been thanked: 14 times
Post by kennethnilsen69 »
I have a calculation I did not get.
Var 1 = 1 (Byte)
Var 2 = 144 (Byte)
Var3 is Int
calculation is:
Var3 = (Var2 / 400) + (Var1 * 100 * 400 * 0.0016)
This should be 1 but I get 0
then I think that the problem is maybe decimals.
so I try:
Var3 = ((Var2 * 100/400) + (Var1 * 100 * 400 * 0.0016)) / 100
but the answer is still 0 instead of 1
I need some help to understand this
Kenneth
Re: Calculatino problems
Hi Kenneth,
I think the problem is that the variables you are storing into is an integer and the calculation may not be doing the order you require.
Var 1 = 1 (Byte)
Var 2 = 144 (Byte)
Instead what about doing this, assuming my brackets are correct.
Var3 = (Var2 / 400)
Var3 = Var3 + (((Var1 * 100) * 400) * 0.0016)
This works out as below so I assume my brackets are wrong for what you need.
Var3 = (144 / 400) = 0
Var3 = 0 + (40000 * 0.0016) = 64
kennethnilsen69
Thanks but I solved it by using Floating point and a str instead of Init
Var 1 = 1 (byte)
Var 2 = 144 (byte)
Var3 is Floating point
var4_str[4]
calculation is then:
Var4_str = FloatToString$ (Var3)
Then Var_str is 1.00 just as i want :-)
Great, glad it's working for you now.
Still not sure how your ending up with 1 when I get 64 but as long as it's doing what you expect then that's great.
