Nextion Serial Touch TFT G-LCD
Please add any feature requests for Flowcode version 7 here
Alan_37
Has thanked: 51 times
Been thanked: 54 times
Post by Alan_37 »
This would be a nice Touch TFT G- LCD component for flowcode .
--> https://www.itead.cc/wiki/Nextion_HMI_Solution
--> https://www.itead.cc/wiki/Nextion_Instruction_Set
Re: Nextion Serial Touch TFT G-LCD
Hi Alan,
Nice timing!
I've just had one land on my desk this morning. I'll investigate what we can do to simplify things in a component.
Alan_37
Post by Alan_37 »
Hi benj
That is great , I have been playing a bit with the commands
here is what I have discovered so far
Default Baud rate = 9600
ÿÿÿ must be added after each command if not sending from nextion Editor
When using get command to get numeric values nextion Display responds in Hex Value !
Task .......................... Command Example
Change Baud rate to 19200 ---> bauds=19200
Edit Text of t0 ------------------> t0.txt="Hello"
Get t0 value ----------> print t0.txt
Set n0 100 ---------------> n0.val=100
change Background color -> t0.bco=5265 + ref t0
Refrash a Component ----> ref t0
Add Data To Waveform ---> add 1,0,150
When using get command to get numeric values nextion Display responds in Hex Value !!
Get Gauge z0 value ---> get z0.val
Get Number n0 Value --> get n0.val
Get a numeric value of Gauge z0 in text format from Nextion
In Editor Add a variable , set it to type text , object name = va0
than send the following 2 commands .
cov z0.val,va0.txt,0
print va0.txt
SEND RS232 Command From Nextion to MCU --> print "String to send"
Multi line Text -----> t1.txt=t1.txt+"hello \r"
Display String Lenght --> strlen t1.txt,n3.val
