FlowChart to C# conversion
sergioigel
Post by sergioigel »
Can somebody tell me if Flowcode is able to generate a C program directly from a flowchart ?
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: FlowChart to C# conversion
Post by JohnCrow »
Hi Sergioigel
Once you have developed your flowchart, you can compile to C, compile to hex or directly to the chip, which goes through both c and hex.
You will find these and other intermediate files in the folder you have saved the flowchart file in.
However It cannot compile to C#
sergioigel
thank you JohnCrow,
please... what is the diference between C# and C ?
thanks,
Sergio
JohnCrow
Post by JohnCrow »
Hi Sergio
C was the original language.
After that came C++
C++ is similar but has extra commands. A C++ compiler can compile to either C or C++, but A C compiler can only do standard C.
C# was the next generation of compiler. I've never used it myself, but if you google it you will be able to find plenty of information online.
I think its more based round Microsoft .NET
sergioigel
thank you very much
I may be wrong but from memory Microsoft tried to re-write Java in the form of J#. This was very badly received and Microsoft was involved in lots of lawsuits. C# came about as a half way house, trying to be Java but not actually Java.
People who like Java tend to dislike C# and visa versa. I was taught Java and this has served me very well with being able to write code for things like Android phones and Tablets. e.g. you don't need a copy of Windows to be running on the device. Instead you just need a free Java runtime.
So C# is very different from C and C++. Though you can take a C or C++ program and manually port the code into C#. C# is better for Windows programs than C or C++ because of the inherent memory management which makes it harder to do things that will cause system crashes or instabilities. Saying this a C# program is generally far less efficient then a C or C++ program as you have all the management to do on top of the actual program code.
sergioigel
Thank you for your explanation too.
