Hi all,
I was wondering if somebpody could give me information about the ethernet modules?
I have the Pic18F87J60, and I would like to use it on my flowcode 6. Can I use the TCP Components even though they were made to be used with the modules:
Wiznet NM7010A Ethernet Module
Wiznet WIZ810MJ Ethernet Module
Wiznet WIZ610WI Wifi Module
Microchip ENC28J60 Ethernet Module
Espressif ESP8266 Wifi Module
OBS: Or should I use only these modules on flowcode 6 or 7?
Thank you very much
Rod
Flowcode ethernet components for COMM
Re: Flowcode ethernet components for COMM
Hi Rod,
At the moment we do not support internal TCP/IP stacks and only support the external modules you listed.
Benj, I found the ethernet module Wiznet W5100 on a local market.
Can I use it instead of the WIZ810MJ whis is the network module that includes W5100(TCP/IP hardwired chip, include PHY), MAG -JACK (RJ45 with X’FMR) with other glue logics?
Rod
Rod
Hi Rod,
The Wiznet modules are expensive and get rather warm, they are now pretty old hat but largely work.
I would recommend using the Microchip ENC28J60 modules for wired TCP/IP comms as they are dirt cheap on eBay and work really well.
To answer your question yes it should work.Can I use it instead of the WIZ810MJ whis is the network module that includes W5100(TCP/IP hardwired chip, include PHY), MAG -JACK (RJ45 with X’FMR) with other glue logics?
