Problems with sending a string over RS232
Wolfgang Kos
Has thanked: 2 times
Been thanked: 3 times
Post by Wolfgang Kos »
I have problems with sending a string to Bluetooth Modul via RS232 like this:
This will not function:
I will adding 3 Strings to 1 String like this:
SEND_WERT11 = PC_Modus11 + WERT_11 + RETURN
The code will not function:
FCD_047b2_RS232_BLE__SendString(FCV_SEND_WERT11, FCVsz_SEND_WERT11);
This is function fine with 1 string:
FCD_047b2_RS232_BLE__SendString("SUW,12345678901234567890123456789011,1234\r\n", 44);
Here the 3 strings:
PC_Modus11 = "SUW,12345678901234567890123456789011,"
WERT_11 = "1234"
RETURN = "\r\n"
In the log i can see Infos over' FCI_SHEAD'
13.01.2017.c: In function 'main':
13.01.2017.c:3480: warning: pointer targets in passing argument 1 of 'FCI_SCOPY' differ in signedness
13.01.2017.c:3480: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
13.01.2017.c:3481: warning: passing argument 2 of 'FCI_TOSTRING' discards qualifiers from pointer target type
13.01.2017.c:3482: warning: pointer targets in passing argument 1 of 'FCI_SCOPY' differ in signedness
13.01.2017.c:3482: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
13.01.2017.c:3483: warning: passing argument 1 of 'FCI_SHEAD' discards qualifiers from pointer target type
13.01.2017.c:3483: warning: passing argument 3 of 'FCI_SHEAD' discards qualifiers from pointer target type
13.01.2017.c:3484: warning: passing argument 3 of 'FCI_SHEAD' discards qualifiers from pointer target type
13.01.2017.c:3484: warning: passing argument 5 of 'FCI_SHEAD' discards qualifiers from pointer target type
13.01.2017.c:3607: warning: passing argument 1 of 'FCD_047b2_RS232_BLE__SendString' discards qualifiers from pointer target type
What is the error?
Thank you for all infos.
Wolfgang
Has thanked: 481 times
Been thanked: 699 times
Re: Problems with sending a string over RS232
String concatenation has issues/bugs when more than two are added.
So please try to do this in more steps,
e.g.
String = A
String = String + B
String = String + C
Wolfgang Kos
Hello LeighM,
thank you for your Info, i will check... :)
Wolfgang Kos
OK,
the problem is solved, only 2 Strings
