Recently i have started using FlowCode 7, instead of FlowCode5, and in connection to this i have some programs in FlowCode 5, which i would like to continue to work with in FlowCode 7. But this isn't all without problems:
I have a file which was perfectly compiled, and worked fine on my PIC-microcontroller, when I was working with it in FC5. The compiler even said that about 13% of the ROM-space and more than 50% of the RAM-space was unused on the PIC.
When I tryi to compile the same program through FC7 i get following error
0: (1347) can't find 0x73 words (0x73 withtotal) for psect "text20" in class "CODE" (largest unused contiguous range 0x51)
0: (1347) can't find 0x5B words (0x5b withtotal) for psect "text13" in class "CODE" (largest unused contiguous range 0x51)
0: (1347) can't find 0x5B words (0x5b withtotal) for psect "text15" in class "CODE" (largest unused contiguous range 0x51)
0: (1347) can't find 0x41 words (0x41 withtotal) for psect "text3" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x39 words (0x39 withtotal) for psect "text19" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x31 words (0x31 withtotal) for psect "text25" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x27 words (0x27 withtotal) for psect "text26" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x23 words (0x23 withtotal) for psect "text12" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x22 words (0x22 withtotal) for psect "text17" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x22 words (0x22 withtotal) for psect "text18" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x22 words (0x22 withtotal) for psect "text28" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x1F words (0x1f withtotal) for psect "text1" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x1D words (0x1d withtotal) for psect "text16" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x16 words (0x16 withtotal) for psect "strings" in class "STRING" (largest unused contiguous range 0x11)
0: (1347) can't find 0x16 words (0x16 withtotal) for psect "text23" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x13 words (0x13 withtotal) for psect "text4" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0x13 words (0x13 withtotal) for psect "text24" in class "CODE" (largest unused contiguous range 0x11)
0: (1347) can't find 0xB words (0xb withtotal) for psect "text29" in class "CODE" (largest unused contiguous range 0x4)
0: (1347) can't find 0x8 words (0x8 withtotal) for psect "clrtext" in class "CODE" (largest unused contiguous range 0x4)
0: (1347) can't find 0x6 words (0x6 withtotal) for psect "text10" in class "CODE" (largest unused contiguous range 0x4)
0: (1347) can't find 0x4 words (0x4 withtotal) for psect "text9" in class "CODE" (largest unused contiguous range 0x3)
I would like to hear if someone here can confirm this. The reason i'm curious is that the assembly-file tells me the following
;! Address spaces:
;!Name Size Autos Total Cost Usage
;!BANK3 60 19 2D 9 46.9%
;!BITBANK3 60 0 0 8 0.0%
;!SFR3 0 0 0 4 0.0%
;!BITSFR3 0 0 0 4 0.0%
;!BANK2 60 0 0 11 0.0%
;!BITBANK2 60 0 0 10 0.0%
;!SFR2 0 0 0 5 0.0%
;!BITSFR2 0 0 0 5 0.0%
;!BANK1 50 0 3E 7 77.5%
;!BITBANK1 50 0 0 6 0.0%
;!SFR1 0 0 0 2 0.0%
;!BITSFR1 0 0 0 2 0.0%
;!BANK0 50 40 44 5 85.0%
;!BITBANK0 50 0 0 4 0.0%
;!SFR0 0 0 0 1 0.0%
;!BITSFR0 0 0 0 1 0.0%
;!COMMON E 6 A 1 71.4%
;!BITCOMMON E 0 0 0 0.0%
;!CODE 0 0 0 0 0.0%
;!DATA 0 0 B9 12 0.0%
;!ABS 0 0 B9 3 0.0%
;!NULL 0 0 0 0 0.0%
;!STACK 0 0 0 2 0.0%
;!EEDATA 100 0 0 0 0.0%
Andreas
