Hi All,
Can anyone guide me on what to do here. I have started up me flowcode 6 after a long while and did a small program, tried to compile it but it just kept going for ever. When I eventually clicked cancel I got a "boostc error code 255".
Any ideas?
I have tried the excluding the boost c file in my anti virus (bitdefender) and have unistalled and reinstalled flowcode 6 but it still the same.
My flowcode 5 is the same too.
Many thanks for your help in advance
Tony
Boostc error code 255
Tony Brown
- Has thanked: 36 times
- Been thanked: 5 times
Re: Boostc error code 255
Hi Tony,
To me it does sound like external app like a firewall (comodo for example) or AV is preventing the files to run.
have you tried disabling all security software including windows defender and firewalls (you can always pull the net cable out if that worries you ) and recompile.
Then if works just keep enabling security software one at a time until flowcode fails to compile.
The other thing can be the compiler settings.
Can you post all the settings e.g
for flowcode V6:
Compiler
Paramerters:
Linker/ Assembler
Paramerters:
for flowcode V6:
Compiler
$(appdir)compilers\pic\boostc\boostc_$(family:/12F/16F).exeCode: Select all
-v -t PIC$(chip:u) "$(target).c"Location:
$(appdir)compilers\pic\boostc\boostlink_picmicro.exeCode: Select all
-ld "$(appdir)compilers\pic\boostc\lib" libc_$(family:/12F/16F).lib rand_$(family:/12F/16F).lib float_$(family:/12F/16F).lib "$(target).obj" -t PIC$(chip:u) -d "$(outdir:~-1)" -p "$(target)" -swcs 6 2Martin
Tony Brown
Thanks for your help Martin, I managed to find out how to disable the anti virus of bit defender and sure enough it work.
Hi Tony,
Glad it's sorted.
Thanks for letting us know as it could help others having same issues as you.
Glad it's sorted.
