ADC BUG?
hertz89
Been thanked: 3 times
ADC BUG?
Post by hertz89 »
hi again
i was working with my friend on project using 16f886
when we set ADC external Vref+ ..the adc not work
he looked at the file PIC_CAL_ADC.c and changed "if (Vref != 0) st_bit(adcon0, VCFG0); " to "if (Vref != 0) st_bit(adcon1, VCFG1);" and the Vref+ worked fine
he have flowcode v5 ..i think 5.5 may be
// ADC Type 7 Supported Devices ************************************************************
// 16F883, 16F884, 16F886, 16F887
#ifdef MX_ADC_TYPE_7
        void FC_CAL_Enable_ADC (MX_UINT8 Channel, MX_UINT8 Conv_Speed, MX_UINT8 Vref, MX_UINT8 T_Charge)
                adcon1 = 0x00;
                switch (Channel)
                        #ifdef MX_ADC_CHANNEL_0
                                case (0):
                                        tris_mask = 0x01;
                                        tris_reg = &trisa;
                                        ansel = 0x01;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_1
                                case (1):
                                        tris_mask = 0x02;
                                        tris_reg = &trisa;
                                        ansel = 0x02;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_2
                                case (2):
                                        tris_mask = 0x04;
                                        tris_reg = &trisa;
                                        ansel = 0x04;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_3
                                case (3):
                                        tris_mask = 0x08;
                                        tris_reg = &trisa;
                                        ansel = 0x08;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_4
                                case (4):
                                        tris_mask = 0x20;
                                        tris_reg = &trisa;
                                        ansel = 0x10;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_5
                                case (5):
                                        tris_mask = 0x01;
                                        tris_reg = &trise;
                                        ansel = 0x20;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_6
                                case (6):
                                        tris_mask = 0x02;
                                        tris_reg = &trise;
                                        ansel = 0x40;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_7
                                case (7):
                                        tris_mask = 0x04;
                                        tris_reg = &trise;
                                        ansel = 0x80;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_8
                                case (8):
                                        tris_mask = 0x04;
                                        tris_reg = ⧍
                                        anselh = 0x01;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_9
                                case (9):
                                        tris_mask = 0x08;
                                        tris_reg = ⧍
                                        anselh = 0x02;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_10
                                case (10):
                                        tris_mask = 0x02;
                                        tris_reg = ⧍
                                        anselh = 0x04;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_11
                                case (11):
                                        tris_mask = 0x10;
                                        tris_reg = ⧍
                                        anselh = 0x08;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_12
                                case (13):
                                        tris_mask = 0x01;
                                        tris_reg = ⧍
                                        anselh = 0x10;
                                        break;
                        #endif
                        #ifdef MX_ADC_CHANNEL_13
                                case (13):
                                        tris_mask = 0x20;
                                        tris_reg = ⧍
                                        anselh = 0x20;
                                        break;
                        #endif
                old_tris = *tris_reg;        //store old tris value, and set the i/o pin as an input
                *tris_reg = old_tris | tris_mask;
                adcon0 = (0x01 | (Conv_Speed << 6)) | (Channel << 2);        //turn ADC on
                if (Vref != 0)        //assign VREF functionality
                delay_us(T_Charge);        //wait the acquisition time
                adcon0 = adcon0 | 0x02;        //begin next conversion
        MX_UINT16 FC_CAL_Sample_ADC (MX_UINT8 Sample_Mode)
                MX_UINT16 iRetVal;
                while (adcon0 & 0x02);
                if (Sample_Mode)
                        iRetVal = (adresh << 2);                                                        //10-bit ADC
                        iRetVal = iRetVal | (adresl >> 6);
                else
                        iRetVal = adresh;        //8-bit ADC
                return (iRetVal);
        void FC_CAL_Disable_ADC ()
                *tris_reg = old_tris;        //restore old tris value, and reset adc registers
                ansel = 0x00;
                adcon0 = 0x00;
                #ifdef ANSELH
                        anselh = 0x00;
                #endif
#endif
Has thanked: 481 times
Been thanked: 699 times
Re: ADC BUG?
Thanks for that, yes it should be adcon1, I will update our file.
Although the datasheet for the device indicates VCFG0 set for Vref+ and VCFG1 set for Vref-
Thanks!
Leigh
hertz89
Re: ADC BUG?
Post by hertz89 »
you welcome
Has thanked: 1135 times
Been thanked: 299 times
Re: ADC BUG?
Post by jgu1 »
Hi!
I also still use Fc5. I am also very interested to have the corrected file if possible. :D
Thanks in advance
Jorgen
Re: ADC BUG?
attached
PIC_CAL_ADC.c
(89.8 KiB) Downloaded 374 times
