How to use a switch, but the case is a range ( not a fix number )
like 1-500,501-1000,1001-1500
Use a switch with a range ( not a fix number )
- Has thanked: 182 times
- Been thanked: 179 times
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Use a switch with a range ( not a fix number )
That is not possible. You will need to use decision icons to check ranges.
― C.S. Lewis
― C.S. Lewis
Yep Kersing is correct the switch case will only check for singular values.
In a decision icon you can use something like this to check for a range, val being the variable you're checking.
(val >= 1) && (val <= 500)
Thanke You both
With this help I did a C Code...
It's small in the mainpart and the big part is easy to copy-paste.
FC7 is really nice to use
