Hello everyone
Want RC interupt for MIAC (Arduino) MI5466 user ATmega1281.
I want signal from RC Receiver to below interrupt:
INT0 = B0 ATmega1281 pin No.:10
INT1 = B1 ATmega1281 pin No.:11
INT2 = B2 ATmega1281 pin No.:12
INT3 = B3 ATmega1281 pin NO.:13
INT4 = B4 ATmega1281 pin No.:14
Can interrupt used ?
Is this possible?
If yes, the output-pin must then be used for the above?
Yours sincerely
RC INTERUPT for MIAC (Arduino)
- Has thanked: 17 times
- Been thanked: 46 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: RC INTERUPT for MIAC (Arduino)
Hi Monie,
Sorry for late reply.
Port B is not externally accessible.
Page 21 of the MIAC datasheet gives to the processor pin usage map for the MIAC.
The I1 and I2 MIAC inputs are connected to Port G0 and G1 if that is of any help.
Leigh
Leigh
Hi Leigh,
Are there others in the MIAC series
which can C ++ and have access to interrupt?
So enlighten me kindly type and order number!
Hi Leigh,
Hi Leigh,
Best Regard
Monie
Monie
- LeighM
Hi Monie
The dsPIC version inputs I1 and I2 are connected to RB0 and RB1.
I will need to check the datasheet to see if IOC can be mapped to those pins,
however it is still only the two,
is it possible for you to wire OR the outputs to give one interrupt,
upon which you can then poll all inputs?
Leigh
Leigh
- LeighM
Hi Monie,
For polling I mean reading the state of the input within the main loop of the program.
So it depends upon the maximum time between polling/reading the inputs and how long the input active pulse lasts,
and how quickly you need to take action after the start of the input pulse.
If that is not feasible, then on the dsPIC, RB0 and/or RB1 can be configured to interrupt on change.
So all 5 of your inputs, as well as going to Ix inputs, could possibly be wire OR'd (via diodes) into say I1 (RB0) to generate the interrupt,
the interrupt code would then read the state of all the 5 inputs.
https://en.wikipedia.org/wiki/Wired_logic_connection
Hi Leigh,
Thanks for fine documented information.
Will the project forward
Best Regard
Monie
Monie
