ESP-8266 com port injector
petesmart
Has thanked: 187 times
Been thanked: 140 times
Post by petesmart »
Hi MTSL team,
I'm currently working with the ESP – 8266 Wi-Fi module on both EB 091 and dsPic mica products. In the past I found the simulation of devices via the PC com port to be very powerful. What this allowed me to do is to substantially complete development prior to loading on target hardware – saves an enormous amount of time and reduces the number of bug significantly.
Looking at the ESP – 8266 component there appears to be a field in the properties window that supports an injector. When you click on this field there is no drop-down box that allows you to pick up an injector or a comms port. Not sure if this is a bug/intended consequence or quite likely I'm doing something wrong.– See image below
is it possible to simulate the ESP 8266 component via an external com port?
All the best
Pete
(87.68 KiB) Not downloaded yet
sorry about that Chief!
Re: ESP-8266 com port injector
Hi Pete,
I see the property for the injector in the component, but you're right it currently does nothing. I'll see how much of a job it would be to add it.
Hopefully it's not too much of a task.
petesmart
Post by petesmart »
Thanks Ben,
Currently trying to interface the dsPic miac to Thingspeak... The syntax for the Thingspeak API can be quite tricky to get right – I figured if I could simulate this it would cut down a lot of time in recompile/download/test etc...
The idea behind connecting miac to Thingspeak is to capture the miac data in the cloud and then use the inbuilt Matlab functionality to analyse and display the collected data – will be really cool if it works :wink: !
If you're interested I will keep you updated with my progress.
Thanks again for looking at this for me.
All the best,
Pete
petesmart
Post by petesmart »
Hey Ben,
I understand that you are very very busy at the moment, and my apologies for being a pain in the proverbial backside!
Any thoughts on when this function might be addressed?
The other thing that is a complete pain in the backside at the moment is that the interrupt simulation in the latest version of FC 7 appears to be broken – or maybe I'm doing something wrong?.
If this is a bug, any idea when this might get looked at.
The good thing about these two little problems is that it is forced me to use the simulation/event capabilities of FC 7 – I have learnt a lot, it's really powerful!
BTW - have you had a chance to check out the thingsspeak IOT portal yet? https://thingspeak.com/channels/254968
Thanks again for all your tireless support
All the best
Pete
Thanks Pete,
We're aware of the interrupt simulating bug that crept in and hopefully we are going to provide a new exe shortly in the updates zip file that should solve the issue.
I'll see if I can get the ESP8266 injector stuff in and working for you as I agree that it's very useful to have.
petesmart
Post by petesmart »
Thanks for the response Ben, much appreciated....
Hi Pete,
Do you want to give this a whirl, I think the injector should be fully supported now but I could be wrong. I've not tested it so do let me know if you spot any issues.
WLAN_ESP8266.fcpx
(26.03 KiB) Downloaded 379 times
There is a slight complication in that the simulation also works via the TCP Base component allowing us to simulate webpage serving from Flowcode.
Hopefully both the webpage simulation and injector comms should work seamlessly side by side but you never know :D
Both feed the same circular buffer so hopefully it will be fine.
Edit: I'm wrong it is an issue especially for the server functionality, client might be ok. Let me think on it.
petesmart
Post by petesmart »
Hi Ben,
Thanks so much for whizzing this around so quick. I've done a quick test on the component, it does not appear to have the ability to select a PC com port as an injector – am I missing something?
I have checked the version of the component – 16.1832. Is this the right one?
All the best
Pete
petesmart
Post by petesmart »
Hi Ben,
I've had the opportunity to take a more detailed look at the new component.
It does not give you the ability to select a physical com port from the PC as an injector source. As a test I added the com port injector icon on the 3D window – this didn't make any change to the ESP8266 component injector input. Not sure if it would but I thought I'd give it a try?
Perhaps I don't have the correct version?
I have attached the test program to assist your further investigation
All the best
Pete
new esp8266 component.fcfx
(11.83 KiB) Downloaded 374 times
petesmart
Post by petesmart »
Hi Ben,
I understand that you're very busy at the moment – have you had a chance to have any further look at the ESP 8266 injector?
All the best
Pete
Hi Pete,
Not yet sorry, it's looking like it will take at least half a day for me to sit down and go through this so it works as it should.
Hopefully I'll get onto this early next week for you but there's lots on so we will see.
I see your project is making really good progress, I have two dsPIC MIACs sat on my desk now to develop the MIAC AllCode firmware, one with Bluetooth and one with Wifi so eager to get started and have a play with these.
petesmart
Post by petesmart »
Thanks Ben,
Appreciate you getting back to me. Leigh told me that it's manic at MTSL at present..whilst can be tiring it's a good problem to have :wink:
Perhaps I might be able to assist, happy to have a look at the component code to see if it's anything obvious.
Allcode project sounds really interesting.....l have quite a bit of stuff now in my MIAC library..happy to contribute if I can.
Best
Pete
petesmart
Post by petesmart »
Hi Ben,
Welcome back from leave..
Any chance I could get this one closer to the top of your list please?
Best regards
Pete
