Dear sir i post the simple program that no reponse of the slave MODBUS component.
with modbus poll (i testing and validate the serial with the master modbus component its working correctly and µc it s ok )
Thank you for your colaboration to resolve this problem.
Best regards
C.Largy
Modbus Slave
Modbus Slave
- testing with adress slave at 0 with 1 i have time out error
- pbmodbusslave.jpg (72.81 KiB) Viewed 4589 times
- Flowcode1.fcfx
- (11.25 KiB) Downloaded 291 times
Re: Modbus Slave
I have allready tested in my first program and the probem is present with checkforincomming macro, i think the problem is at the adress number check.
My program is very simple for my test i want just read a holding at 40001 on my cpu.
Thank your for your help.
C.LARGY
C.LARGY
Re: Modbus Slave
I have Moved both posts from this topic
As you're hijacking someone else's topic & you're using Atmega and not PIC.
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Re: Modbus Slave
Hi cedlgy
You are not calling the component macro "checkforincomming" on the Modbus component
there is an example here
http://www.flowcode.co.uk/wikiv7/images/ ... mple1.fcfx
Modbus wiki here
http://www.flowcode.co.uk/wikiv7/index.p ... orIncoming
Modbus wiki here
Re: Modbus Slave
I am sorry my intention is not to pertub your post I just want to solve the problem with component modbus slave and the problem is common with tow family PIC and ATMELmedelec35 wrote:I have Moved both posts from this topic
Best regards.
C.Largy
