Hi everybody!
A technical question about Flowcode7 and I2C master component.
I have a slave device with just one byte internal address.
The question: How can I work with Rx or Tx ByteTransaction macro when I haven't 2 byte internal address?
If I leave blank the AddrH or AddrL line, it makes an error massage.
Has anyone a solution for this problem?
Thanks!
I2C internal address
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: I2C internal address
Rather than using the Transactions, you will need to build up your own protocol, to match what the device requires,
such as Start, TransmitByte, Restart, ReceiveByte, Stop
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
Have you tried this on hardware?
I have had experience in which the slave device ignores the hi byte addr - it work by setting the addr 0
just a thought it possibly hardware dependent?
sorry about that Chief!
petesmart wrote:Have you tried this on hardware?
Thanks, I will try it....
Hi, yes I usually use this method what you wrote. I have asked, because maybe there is a comfortable solution. Thanks!LeighM wrote:Rather than using the Transactions, you will need to build up your own protocol, to match what the device requires,
