FAT Append String to file
alikimiafar
Has thanked: 1 time
Post by alikimiafar »
I use flow code6 and pic 18f26k22 ,conect micro to sd but have 2 problems
1. Ì can't create a file name more than 4 charector .....why?
2. When append string to file in line 46 some txt write on line 35 .....
I saw a problem in (viewtopic.php?f=64&t=18356) look like my problem that Benj fix it and send new FAT.fcpx file for flowcode7
But my problem in flowcode6 and I cant use this file for my flowcode6
Please help me and send FAT.fcpx
This is "data.txt" file that micro write in microsd file
Look at line 35 and 46
input is 1000000000 245 at 17/05/23 16:16:48
input is 0000000000 245 at 17/05/23 16:16:49
input is 1000000000 245 at 17/05/23 16:16:51
input is 0000000000 245 at 17/05/23 16:16:51
input is 1000000000 245 at 17/05/23 16:16:53
input is 0000000000 245 at 17/05/23 16:16:54
input is 1000000000 245 at 17/05/23 16:16:56
input is 0000000000 245 at 17/05/23 16:16:57
input is 1000000000 245 at 17/05/23 16:16:58
input is 0000000000 245 at 17/05/23 16:17:00
input is 1000000000 245 at 17/05/23 16:17:04
input is 0000000000 245 at 17/05/23 16:17:05
input is 1000000000 245 at 17/05/23 16:17:07
input is 0000000000 245 at 17/05/23 16:17:09
input is 1000000000 245 at 17/05/23 16:17:10
input is 0000000000 245 at 17/05/23 16:17:12
input is 1000000000 245 at 17/05/23 16:17:13
input is 0000000000 245 at 17/05/23 16:17:15
input is 1000000000 245 at 17/05/23 16:17:18
input is 0000000000 245 at 17/05/23 16:17:20
input is 1000000000 245 at 17/05/23 16:17:21
input is 0000000000 245 at 17/05/23 16:17:23
input is 1000000000 245 at 17/05/23 16:17:26
input is 0000000000 245 at 17/05/23 16:17:27
input is 1000000000 245 at 17/05/23 16:17:29
input is 0000000000 245 at 17/05/23 16:17:31
input is 1000000000 245 at 17/05/23 16:17:33
input is 0000000000 245 at 17/05/23 16:17:36
input is 1000000000 245 at 17/05/23 16:17:38
input is 0000000000 245 at 17/05/23 16:17:41
input is 1000000000 245 at 17/05/23 16:17:44
input is 0000000000 245 at 17/05/23 16:17:46
input is 1000000000 245 at 17/05/23 16:17:47
input is 0000000000 245 at 17/05/23 16:17:50
input at 17/05/230 245 at 17/05/23 16:17:52
input is 0000000000 245 at 17/05/23 16:17:55
input is 1000000000 245 at 17/05/23 16:17:58
input is 0000000000 245 at 17/05/23 16:18:00
input is 1000000000 245 at 17/05/23 16:18:03
input is 0000000000 245 at 17/05/23 16:18:06
input is 1000000000 245 at 17/05/23 16:18:08
input is 0000000000 245 at 17/05/23 16:18:10
input is 1000000000 245 at 17/05/23 16:18:13
input is 0000000000 245 at 17/05/23 16:18:16
input is 1000000000 245 at 17/05/23 16:18:22
alikimiafar
Has thanked: 1 time
Re: FAT Append String to file
please help me
alikimiafar
Has thanked: 1 time
Benj please help me .....you solved this problem for flowcode7 But I use flowcode6 .....
Hi alikimiafar,
Ben is on holiday all next week.
So please bear with for a while longer.
alikimiafar
Has thanked: 1 time
Ok I am waiting....to come back....
alikimiafar
Has thanked: 1 time
Hi Benj
Please help me !
Sorry for the delay. Please can you try this and see how you get on.
Simply copy the attached file into your "Flowcode 6/components" directory and restart Flowcode.
FAT.fcpx
(66.24 KiB) Downloaded 470 times
alikimiafar
Has thanked: 1 time
hi Benj
thanks very much :D
very good my problem number 2 solved
but I cant create file name bigger than 4 character for example :
I can create data.txt but I cant create flowcode.txt (with more than 4 character) and on sd card just create flow.txt What is the problem?
Glad this has fixed the append issue for you.
I haven't come across this issue before the file name "flowcode.txt" should be fine. Have you tried a different card to make sure it's not a card specific thing.
