MIAC 8 bits controlling a DC motor > 1.75A
go233
Has thanked: 5 times
Been thanked: 11 times
Post by go233 »
I would like to control 2 DC Motors;
they absorb more than 3A each.
I need also to change rotation direction of both.
Could you give me any suggestion, please?
Giovanni
Has thanked: 481 times
Been thanked: 699 times
Re: MIAC 8 bits controlling a DC motor > 1.75A
Do you need speed control, or just on/off?
Perhaps you could use two MIAC relays to control the on/off power supply,
and use another pair of relays (or solid state outputs) to drive a pair of external DPDT relays to control direction.
Docara
Has thanked: 28 times
Been thanked: 61 times
Post by Docara »
More info required
What voltage for the motors
What control signal voltage (inputs)
3A ??? What is the peak value
Check the DRV 8*** range of MOSFET Bridge drivers eghttp://www.ti.com/lit/ds/symlink/drv8829.pdf is one I found with a quick Internet search
Hope it helps
Matt
go233
Post by go233 »
The motor is
RS Pro DC Geared Motor, Brushed, 12 V, 4.5 → 15 V dc, 2000 gcm, 3090 rpm, 19.8 W
RS Stock No.454-0877
Brand RS Pro
Mfr. Part No.942D51
the specs are attached to this post.
I think is a 2.85A at 12V.
Yes I would like to have speed control, too: I think if I connect the A and 0V to the input of an SSR I might sort it out?
Farnell
D1D20 - SSR, PANEL MOUNT, 100VDC, 32VDC, 20A
Manufacturer: CROUZET AUTOMATION
Manufacturer Part No: D1D20
Order Code: 1533374
What do you think?
Giovanni
Docara
Post by Docara »
Hi Giovanni,
http://www.robotshop.com/uk/36a-drv8871 ... board.html - Assembled Board (£6ish)
http://www.ti.com/lit/ds/symlink/drv8871.pdf - Data sheet
Look at pages 8,9,10,11
You will see from the table on page 8 that you will need two PWM pins to fully control the motor with forward reverse and brake or toggle for 100% speed forward or reverse.
Page 9 how to limit the maximum current if desired
Page 10 outlines the inbuilt protection available
Page 11 shows a basic example of how to connect up
Edit : just seen this https://www.pololu.com/product/1213 and this http://www.hobbytronics.co.uk/dual-6a-d ... controller
Matt
go233
Post by go233 »
Hi Matt,
Ok, I will buy the driver and I will post my results.
(give me a week or so)
thank you!!!
Giovanni
Docara
Post by Docara »
Hi Giovanni,
Please check and verify for yourself if they are suitable for your specific requirements, don't just buy one because of my suggestion.
Matt
