ADC Component change ref voltage
- Has thanked: 460 times
- Been thanked: 523 times
Afternoon all
using a PIC16F18875 and I want to change the internal ref voltage to 1.024 volts
http://www.matrixtsl.com/wikiv7/index.p ... a0dd265bce
I am not 100% sure on how to change this, don't fully under stand the wiki
If someone could advise
Re: ADC Component change ref voltage
Hi Steve,
Change the VRefOption to FVR.
Change the VRefVoltage to 102.
Then use the following C code to configure the FVR peripheral.
Hopefully that should be all that is required.
FVRCON = 0x81;
Afternoon
trying to get analogue input working, reading not making any sense at all
Connected LM35CAZto port E0
http://uk.farnell.com/texas-instruments ... st=9494529
test program reading not stable what so ever 0.000031 - 1.015899 voltage on scope 256mv which is probably correct for temperature in room
not 100 % sure if I have analogue port settings correct
if someone can advise
:edit
the plot thickens
1) tried the example file from the wiki - "Reading a sample as a Voltage" changed target device to PIC16F18875 and 4 x 16 display - example didn't work read rubbish
2) exact same example and setup - target device ECIO40P - working correctly
changed back to test 1
measured voltage with scope on chip input pin - correct
changed analogue inputs to different pin - not working (AN32 - RE0)
so is the problem with my device setup or is there something else a miss ?
:edit
the plot thickens
Hi Steve,
What chip pin number have you connected the analogue signal to?
then adding C code code block with would not work?
Steve,
Have you read this thread?
In your case you will need to search for instead of
To me that sounds like the port is floating so wrong pin is being read or there is a bug with ADC.Steve001 wrote: test program reading not stable what so ever 0.000031 - 1.015899 voltage on scope 256mv which is probably correct for temperature in room
I would have thought since this is set withinBenj wrote: Then use the following C code to configure the FVR peripheral.Code: Select all
FVRCON = 0x81;
PIC_CAL_ADC.c
FVRCON = 0x81;
Steve,
TYPE_34
TYPE_26
Hi Martin
I am using port E0 (pin8) - i have checked the pin voltage is correct with my scope
I was looking at that post this afternoon, wasn't too confident in looking into that or fiddling with the code.
I will sit down tomorrow and have a go through it when i have a clear head
:edit
I also checked by using the example file in the wiki AN0, AN1, AN32 using standard analogue port settings - readings meaning less
:edit
Hi Steve,
This is a long shot.
Can you connect the voltage to be measured to Pin 2 (AN0) and see what the Display reads?
Hi Martin,
I checked by using the example file in the wiki AN0, AN1, AN32 using standard analogue port settings - readings meaning less
Hi Steve, I was suspecting registers not being assigned with correct values?
There is a way to find out.
You could read the registers then send value to LCD.
Would you know how to do that?
Hi Martin
To be honest I don't have a clue
If you can help me out with that one please
Sure,
I will put something together tomorrow for you.
Hi Steve,
Don't know if the attached file will help?
It will display the register name and below will display the register value in binary which makes it easier to compare with the data sheet.
- analougue test 2.fcfx
- (22.05 KiB) Downloaded 359 times
Hi Martin
Connected my LM35 to E0 - measured 233.1mv on scope
cannot make end or tail of this
I let it run for 4 passes and got different results
Looking at the FVRCON Register 11000001
Fixed Voltage Reference is enabled
Fixed Voltage Reference output is ready for use
Temperature Indicator is disabled
VOUT = VDD - 2VT (Low Range)
Comparator FVR Buffer is off
ADC FVR Buffer Gain is 1x, (1.024V)
or have I read this the wrong way round ? and why is ADC different values
looking at page 267 on data sheet
http://www.farnell.com/datasheets/22452 ... 1501615565
Hi Steve,
From your results it looks like ADCON0 is either not being assigned correctly or it's being cleared within PIC_CAL_ADC.c
On further investigation its the latter.
In order to view ADCON0 SFR:
Can you make a back up copy of PIC_CAL_ADC.c in if 64 bit windows
or if 32 bit windows.
Then replace original with attached version, which will be for diagnostics only.
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_ADC.c
or
C:\Program Files\Flowcode 7\CAL\PIC\PIC_CAL_ADC.c
- PIC_CAL_ADC.c
- (117.19 KiB) Downloaded 286 times
cheers martin will have a go tonight
do I reprogram device with new file and re run ?
Hi Steve,
I'm interested in what the new ADCON0 results are.
Yes or else there will be no difference in your results.Steve001 wrote:do I reprogram device with new file and re run ?
Hi Steve,
I have noticed some confusion with the datasheet;
It shows on page 344: Which shows to use ADCON0 for analogue channel selection.
Yet further down the datasheet it shows: Can you change one of the registers in the flowchart to and recompile.
Don't forget to refresh flowchart before compiling.
From the results, we could get further.
ADPCH
Hi Martin
do you want me to use the original cal file or your modified one ?
I was reading that data sheet too last night but not as far down as that page, I did notice something that FVR is on port AN1 ???? I was getting confused at this point also too
I will have another go tonight
Hi Steve,
1) Go in to a switch branch of flowchart.
Change a name of both C code and calculation box to desired register.
E.g change & to
Or
2) Add an additional Switch from the flowchart symbols and double click on it.
Change the default to
In change to
Copy any of the two icons e.g &
Paste in the branch of the new switch icon.
Just change the the register names of both icons so you have: & for branch 11.
Finally cut the from branch 10 and paste in the new branch 11.
Recompile flowchart.
Nothing requires changing on cal file:Steve001 wrote:do you want me to use the original cal file or your modified one ?
There are two different ways.medelec35 wrote:Can you change one of the registers in the flowchart to
CODE: SELECT ALL
ADPCH
and recompile.
E.g change
FCV_REGISTER_VALUE=ADCON1;
RegisterName = "ADCON1"
FCV_REGISTER_VALUE=ADPCH;
RegisterName = "ADPCH"
Change the default
Count
Cases:
Finally cut the
Count = 0
No problem.
One thing.
Can you make sure the ADC channel being used within flowchart and hardware is not An0.
Cheers
One thing.
Cheers
Hi Martin
i get the following error when I compile now
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F18875 "analougue test 2.01.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
Copyright (C) 2017 Microchip Technology Inc.
analougue test 2.01.c: main()
1245: FCV_REGISTER_ADPCH;
^ (192) undefined identifier "FCV_REGISTER_ADPCH"
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
have I done something stupid
cannot see anything
input connected to E0 - pin 8 still (AN32)
FINISHED
