EEprom not supported on MPLAB Xpress board? - Solved
chico
Has thanked: 12 times
Been thanked: 10 times
Post by chico »
Hi - I've been working with the MPLAB Xpress board. Very cheap for what you get, love the integration with Flowcode. "Compile to Chip" works great, is better than getting out the ICD3 to program the PIC. Looks like there's been some good interaction with Microchip on this.
However, I just added an EEprom device, and it the compiler barfs:
Target folder: C:\Users\TEST\Desktop
Title:
Description:
Device:        PIC.16F.Microchip MPLABXpress
Generated by:  Flowcode v7.2.1.4
Date:          Saturday, July 08, 2017 13:07:34
Users:         1
Registered to: xxxxx
Licence key:   yyyyy
http://www.flowcode.co.uk
Launching the compiler...
Build date: Apr 12 2017
Part Support Version: 1.42
Copyright (C) 2017 Microchip Technology Inc.
    44:	EEADR = Address & 0xff;
	^ (192) undefined identifier "EEADR"
    52:	EECON1bits.EEPGD = 0;
	^ (192) undefined identifier "EECON1bits"
	                 ^ (196) struct/union required
    53:	EECON1bits.CFGS = 0;
    55:	EECON1bits.RD = 1;
    56:	data = EEDATA;
	       ^ (192) undefined identifier "EEDATA"
    70:	while ((EECON1bits.WR));
    71:	EEADR = Address & 0xff;
    75:	EEDATA = Data;
    80:	EECON1bits.EEPGD = 0;
    81:	EECON1bits.CFGS = 0;
    83:	EECON1bits.WREN = 1;
    86:	EECON2 = 0x55;
	^ (192) undefined identifier "EECON2"
    88:	EECON1bits.WR = 1;
    89:	while ((EECON1bits.WR));
    92:	EECON1bits.WREN = 0;
(908) exit status = 1
FINISHED
I've attached the Flowcode project with no code, just the component, and you can see the compiler errors.
Would very much like to understand how to get this resolved as I'd rather not have to port the entire project to another processor at this point....
Thanks...
FC_mplabxpress_test_001.fcfx
No code or flowcharts, just the EEprom component...
(6.9 KiB) Downloaded 382 times
Re: EEprom not supported on MPLAB Xpress board?
This file should solve the issues for you. Simply copy to your "Flowcode 7/CAL/PIC" folder and the compilation should hopefully now complete correctly.
PIC_CAL_EEPROM.c
(4.46 KiB) Downloaded 372 times
Let me know how you get on.
chico
Post by chico »
Bravo. Works perfectly. Thank you.
