Compiling for 16F505
lgdruyte
Post by lgdruyte »
I have problems with compiling for the 16F505.
I'm not able to compile even an empty program.
Error message
Error message
Program
Program
I use the default compiler settings.
Compiler settings
Compiler settings
i have no problems with other microchips.
Does anyone know what's going wrong.
Thanks in advance,
Lucas
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Re: Compiling for 16F505
Post by EtsDriver »
Hi!
Could you try these files and see does it help? I put the backup files there too, if it doesnt help.
Changelog:
CAL\internals.c: line 71, see comment on line 70.
FCD \PIC\16F505.fcdx: line 70, see comment on line 69.
Flowcode will still give you a reminder about the low ram mode:
C:\Program Files (x86)\Flowcode 7\CAL\internals.c:
    75:			#warning "String temporary variables not defined to save on limited RAM space on your current target device"
	       (162) #warning: "String temporary variables not defined to save on limited RAM space on your current target device" ^ (warning)
I cant say its bug free. I think the Port definitions need some work too...
    82:	FCV_TEST = (FC_CAL_Port_In_DDR__x((&PORTC), (&TRISC), (0xFF), (0)));
	                                                   ^ (1418) attempt to read "control" qualified object which is Write-Only
(908) exit status = 1
16F505_patch.zip
(9.96 KiB) Downloaded 295 times
I think I fixed this problem a few weeks back but haven't posted it yet. I'll get it up on the forums for you tomorrow.
The device has very limited resources so no string manipulation using the current buffer. The io is also more like a 10f than a 16f with a command for the tris rather than a register.
I've now posted all the latest updates here which should solve the problem for you.
viewtopic.php?f=63&t=18760
Let me know how you get on.
