RTC Component
mnf
Has thanked: 70 times
Been thanked: 440 times
RTC Component
Post by mnf »
Just playing with the RTC component - to use a DS3231 with an Arduino.
I was unsuccessful - so tried the DS3231 component uploaded by Jordy and got thing pretty much working as I wished - including an interrupt to wake the Arduino from sleep mode. (Though not all plain sailing - see attachment for details)
I then returned to the 'official' RTC component.
First problem - the i2c address for the clock chip should be writable.
Next - setting the address to that of my RTC (0x57) gave no result.
Looking at the C generated for example for SetYear:
void FCD_0a3a1_RTC1__SetYear(MX_UINT8 FCL_YEAR)
    //Local variable definitions
    MX_UINT8 FCL_DATA;
    if (FCL_YEAR < 100)
        #if (0)
        //Code has been optimised out by the pre-processor
        #else
            #if (0) // 2 == 0
            #else
                #if (1) // 2 == 1 || 2 == 2
                    FCL_DATA = FCL_YEAR % 10;
                    FCL_DATA = FCL_DATA + ((FCL_YEAR / 10) << 4);
                    //Comment:
                    //DS1307 & DS3231
                    FC_CAL_I2C_Master_Start_1();
                    FC_CAL_I2C_Master_TxByte_1(0x57);               *****  i2c write start *****
                    FC_CAL_I2C_Master_TxByte_1(6);
                    FC_CAL_I2C_Master_TxByte_1(FCL_DATA);
                    FC_CAL_I2C_Master_Stop_1();
                // #else
                #endif
            #endif
        #endif
    // } else {
I have added the ** i2c write ** (and changed the address to hex) - however should this really be (0x57 << 1) for an i2c write command?
Or am I missing something here?
sleep.fcfx
(14.73 KiB) Downloaded 471 times
DS3231 example with comments as to some problems
t1.fcfx
(10.91 KiB) Downloaded 478 times
RTC example - doesn't work.
Re: RTC Component
Hi Martin,
Looking at the DS3231 datasheet shouldn't the address be set to 0xD0?
mnf
Re: RTC Component
Post by mnf »
That's the default - but no result using that either..
Should still be 0xD0 << 1 for i2c writes?
This gives 11:51:51 repeatedly..... Even with a set at the start of code..
Re: RTC Component
I believe the 0xD0 already includes the shift.
Write = 0xD0
Read = 0xD0 | 0x01
Sounds like reading may be working? but writing is not. Or neither are working and you are simply reading uninitialised RAM values.
Are you using external pull up resistors on the I2C SDA, SCL signals?
mnf
Re: RTC Component
Post by mnf »
Yes - pullups in place.
Note that the DS3231 example does work - so wiring roughly correct (hopefully)
I've tried with D0 as i2c address (though perhaps the name is incorrect here)
I'll play some more and see if I can get to work - or work out why not working....
mnf
Re: RTC Component
Post by mnf »
Some more experimenting - this time I used a data-logger shield with an inbuilt DS1307.
Using the Arduino library examples SetTime and ReadTest - reveal that the hardware works.
Uploading a simple FlowCode example - read the time - stops the clock chip (checking value by reloading ReadTest). Re-running SetTime restarts it.
An 'empty' flowcode program which only initialises the RTC and UART doesn't have the same effect but any read - ie GetHours(0) - stops the clock...
Looking at the C generated by using the DS3231 library and the FlowCode RTC library the main difference I see is that the DS3231 library (which works!) has an I2C Restart before reading data:
Thus from ReadTemperature (DS3231 library):
    FCD_005f1_I2C_Master1__Start();
    FCD_005f1_I2C_Master1__TransmitByte(FCV_0d1f1_DS3231__WRITE);
    FCD_005f1_I2C_Master1__TransmitByte(0x11);
    FCD_005f1_I2C_Master1__Restart();
    FCD_005f1_I2C_Master1__TransmitByte(FCV_0d1f1_DS3231__READ);
    FCL_TEMPHIGH = FCD_005f1_I2C_Master1__ReceiveByte(0);
    FCL_TEMPLOW = FCD_005f1_I2C_Master1__ReceiveByte(1);
    FCD_005f1_I2C_Master1__Stop();
The RTC library generates:
                FC_CAL_I2C_Master_TxByte_1(208);    // i2c address << 1 | 0
                FC_CAL_I2C_Master_TxByte_1(2);       // Address to read
****   Need an i2c restart here????
                FC_CAL_I2C_Master_TxByte_1(208 | 0x01);   // i2x address << 1 | 1 - read from
                FCL_DATA = FC_CAL_I2C_Master_RxByte_1(1);   // Get 1 byte..
Note this is from GetHours and I've removed a few pre-processor directives to tidy (but not alter) the code.
Looking at the Arduino RTC library code - it also seems to have a restart at the same point.
The 11:51:51 seems to be the 'clock is stopped' default memory values.
mnf
Re: RTC Component
Post by mnf »
Playing with this has also highlighted another bug...
The 'C' code item box can be resized - however the actual edit box and buttons etc are not affected - only the bounding box moves..... After closing and reopening the box the correct (ie enlarged) control is displayed.
Also in the 'C' code view - why do page up and down keys not work..
mnf
Re: RTC Component
Post by mnf »
I tried adding an i2c restart - and indeed this seems to work.
I cut and pasted the generated C code for GetMin into a macro and then edited (I've commented where I added the restart)
This certainly works for GetMin - and I think should fix the other read routines although I don't have time to test this at present.....
The following snippet of FlowCode demonstrates:
ds1307.fcfx
(11.23 KiB) Downloaded 457 times
Re: RTC Component
Hi Martin,
That's brilliant, many thanks for letting me know. I have applied the fix to the component and hopefully it should work correctly for you now.
Simply drop the attached file into your "Flowcode 7/components" directory, restart Flowcode and hopefully the component should now work correctly for you.
RTC.fcpx
(9.82 KiB) Downloaded 495 times
Let me know how you get on.
mnf
Re: RTC Component
Post by mnf »
Thanks,
Certainly seems to work perfectly for reading and writing to RTC - tested with DS1307 and DS3231 (on Arduino ATMega328p using an Uno R3 and a Nano - I'd also rather like to get it working with an ATTiny85 - but that's a project for another day).
Haven't tested all the macros - I'll have a play with interrupts on the DS3231 in more detail - on the DS1307 I got a 1Hz (and 60Hz) interrupt working without difficulty.
