USB serial initialisation not compiling
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
Im trying to use the USB serial coms macro to communicate between the arduino UNO and a Rasberry Pi
The test programme is very simple, just flashing an LED. Without the usb serial initialise macro, programme compiles to chip and works, but as soon as I add the usb serial initialise macro, the system will not compile to hex and displays the attached error message. Am I doing something wrong?
Chris
(49.44 KiB) Downloaded 1465 times
USB test1.fcfx
(9.8 KiB) Downloaded 227 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: USB serial initialisation not compiling
Post by kersing »
Last time I checked the controller of the uno did not support USB. The USB serial on the uno is a separate chip which is connected to RX/TX of the controller (atmega328p).
― C.S. Lewis
Yes Kersing is right, you need to use the UART component rather than the USB Serial component on the Arduino Uno board.
