MFRC522 component
tarmar
MFRC522 component
Post by tarmar »
There are a bugs with with the MFRC522 component. It gives a wrong card ID for MIFARE 1K cards. The first and third number are always the same. I have tried more than 20 cards.
Flowcode card ID read result is 14:152:14:26:92 but it should be 208:152:14:26:92
Flowcode card ID read result is 216:239:216:26:205 but it should be 224:239:216:26:205
Flowcode card ID read result is 152:117:152:26:23 but it should be 224:117:152:26:23
Because of this wrong card ID it is not possible to select a card and make an authentication to the card for a read/write operation.
There is also a mistake in the authentication command. To make an authentication to the MIFARE card, the cards ID must be used which is 5 Byte long. However, the AUTH command of the MFRC522 component has only 4 Bytes for the card ID.
Are these only being trial version limitation or bugs?
TM_MFRC522_RW.fcfx
(23.23 KiB) Downloaded 223 times
Has thanked: 481 times
Been thanked: 699 times
Re: MFRC522 component
Thanks for the post.
Looks like this will need some time to look into.
johnsondav
Has thanked: 86 times
Been thanked: 186 times
Post by johnsondav »
I can confirm that I have tested this module and I too have the same problem - the first data byte is over written by the third data byte.
Dave
