In my program and in the hardware I am using several components, I have connected a Keypad (eb014) A0 A1 A2 A3 and C0 C1 C2 the keypad is only used the first time the circuit is turned on, only the keypad is re-occupied when you change Parameters, when the program is in a stage where the keypad is not required, can I use the Analog input AN0 (A0) for a sensor, without affecting the program or PIC ?
Thank You
Enrique
