"send failed" with ECIOprog and .hex file from flowcode V7
sundgau
Has thanked: 5 times
Been thanked: 10 times
Post by sundgau »
I have a problem with ecioprog and flowcode7.
I can not send .hex program with ECIOprog; I have the message "Send failed" ...
My program works with the compilation in chip directly under flowcode.
What the matter?
Bruno
(16.96 KiB) Downloaded 1793 times
sundgau
Re: "send failed" with ECIOprog and .hex file from flowcode V7
Post by sundgau »
Ok, I just understood that you have to use the "mloader.exe" program!
Sorry!
Bruno
Is everything working correctly using mLoader?
It could be that the .hex file you're sending has not been built for the ECIO target? In Flowcode check that your target device is set to ECIO28P or ECIO40P and not the 18F device. The ECIO targets shift the .hex file so that it is compatible with the in-built USB bootloader.
Jay Dee
Has thanked: 121 times
Been thanked: 154 times
Post by Jay Dee »
Just to confirm.. what is the intended use of ECIOprog?
I just assumed this was an external programmer for sending to ECIO products, which by default have the bootloader enabled?
I also have a program that compiles and sends correctly in FC7 (device type is ECIO28)
But if I try to send the same .hex file I also get the 'Send Failed'.
J.
ECIOprog is now legacy and was the original programming software for ECIO. This has now been fully replaced with mLoader which is supplied with Flowcode in the tools folder or can be downloaded separately here.
http://www.matrixtsl.com/resources/getr ... php?id=884
Jay Dee
Post by Jay Dee »
Ah ha! Thanks for clarification Ben. All good. J.
