I managed to do this successfully on an Arduino (as there are many example sketches out there) but I want to do my project using an STM Nucleo (F103RB). I tried to transfer the example code over, and edit it using commands the online mbed IDE would understand, but it would not work. I then found a few different examples and each gave me different results. I eventually came up with my own code following a guide in adding/subracting in the book 'C Programming: A mordern approach'. The code I have come up with is here:
#include "mbed.h"
#include "TextLCD.h"
DigitalIn ip(D7);
TextLCD lcd(A0, A1, A2, A3, A4, A5);
int i =0;
int main() {
lcd.cls();
lcd.locate(0,0);
lcd.printf("COUNT:");
lcd.locate(0,1);
lcd.printf("%d",i);
while(1) {
if (ip ==1) {
lcd.locate(0,1);
lcd.printf("%d", ++i);
And finally, the count started responding when I pushed the button. However, the issue I am having, is that the count increments all the time I have the button pressed, so even a small press will increase the count by 50-80 (depending how quickly you press it) and I want it to increment by 1 each press.
I have tried structuring it differently, having the 'while' statement at the beginning etc, but that just caused the LCD to oscillate strangely.
I've been stuck on this for about 6 hours now before getting to this point! Would really appreciate if someone could give me some pointers in the right direction!
In case anyone is needing it, my (simplified) schematic is here:
So you can see it really is very simple. But I have just zero knowledge of C programming and have never been taught how to do it properly, so any solutions will need to be explained!
Thank you!
