Hi all.
So I`ve been trying to use the I2C Eeprom component without any success, has anybody else used it since upgrade 7.3?
It compilates ok, but when running the program it stops in the Read command.
The MCU speed seems ok after running the "blinker test" at several rates and also PWM channels runns at calculated speed.
Target is: 24EP512GU810@140Mhz
Annybody got a clue?
electronix.
Serial Eeprom 24C32 not working
electronix
- Has thanked: 17 times
- Been thanked: 7 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Serial Eeprom 24C32 not working
Could you just check that the channel and port properties are correct in your project for the eeprom component?
There is a chance that the defaults have changed.
If it still fails, could you change to the "Software" channel and see if that works.
electronix
Hi Leigh.
I just did the last upgrade of 7.3 and after some testing it seems to work in both HW and SW mode, so I guess its working, I will use it in a project later on though for proper testing.
Thanks a lot
Thanks a lot
