gLCD ST7565R1
Boomer
gLCD ST7565R1
Post by Boomer »
Hi Guys
I have created a small program with the above LCD Display.
(13.49 KiB) Downloaded 988 times
As can be seen there is two readings 001 and 0.
If the number value goes above 100 the digits don't align on the decreasing value.
ie the number 1 stays in the hundred's column.
any ideas how I can change this without clearing the screen completely
Best Regards
Ian
Re: gLCD ST7565R1
Hi Ian,
Before printing your number you need to make a decision if the number is less than 10 and less than 100. If it is then print out some padding 0's.
Here is some pseudo code.
if (number < 100)
PrintString ("0")
if (number < 10)
PrintString ("0")
PrintNumber (number)
Hope this helps.
Boomer
Re: gLCD ST7565R1
Post by Boomer »
Thanks a bunch Benj, got it now
Appreciate your help
Ian
