I use FC7 and I try make simple programm with internal oscillator enabled.
I added C-code in the begining of programm and set internall oscillator in options.
But PIC is work very slow. I want it be work on 8MHz.
Where is my mistake?
PIC18F2520 problem with OSCCON register
maharadga
- Has thanked: 17 times
- Been thanked: 12 times
- Int_Osc_Test.fcfx
- (8.02 KiB) Downloaded 226 times
Re: PIC18F2520 problem with OSCCON register
That all looks correct to me. Have you tried the 1 second flash test to try and see what speed your actually running at?
https://www.flowcode.co.uk/wikiv7/index. ... ED_flasher
maharadga
Thanks for the quick answer.
I found mistake. In test circuit board MCLR is unpinned.
I want PLL 4 MHz frequency in this mode/int osc/ to be 16MHz.
Do I do it right?
Because if I set 16MHz in options LED flash 4 times slow. If I set 4MHz it's Ok.
Do I do it right?
- Int_Osc_Test_Flasher.fcfx
- (8.01 KiB) Downloaded 219 times
maharadga
I solved it. Must change order of C-code
OSCTUNE=0x5F;
OSCCON=0x60;
to
OSCCON=0x60;
OSCTUNE=0x5F;
and frequency in settings must be 16MHz.
Apparently the order of writing is important.
OSCTUNE=0x5F;
OSCCON=0x60;
to
OSCCON=0x60;
OSCTUNE=0x5F;
