Loop index
mnf
Has thanked: 70 times
Been thanked: 440 times
Loop index
Post by mnf »
I've seen similar to this reported back in 2014.
A loop with a count > 255 needs a word as the index and this indeed now works when using an integer count.
However if using a variable as the loop index then flowcode only assigns a byte variable.
[img]
(8.02 KiB) Downloaded 1070 times
[/img]
Generates (correctly)
MX_UINT16 FCLV_LOOP1;
    for (FCLV_LOOP1=0; (FCLV_LOOP1)<(1000); (FCLV_LOOP1)++)
Whereas
[img]
(6.47 KiB) Downloaded 1070 times
[/img]
Where x is greater than 8 bits generates the following C
MX_UINT8 FCLV_LOOP1;
    for (FCLV_LOOP1=0; (FCLV_LOOP1)<(FCV_X); (FCLV_LOOP1)++)
Which of course fails if x > 255 - FCLV_LOOP1 should mirror the type of 'x'
A workaround is easy - using a user-defined loop variable in a 'for' loop or a 'repeat until' loop.
It can catch the unwary however.....
Re: Loop index
Thanks Martin,
Yes this has caught me out too, I'll flag it up as a bug in the system.
