EB066-00-4 Test Procedure
JackG
Post by JackG »
I have recently purchased EB006-00-4 to start a simple project of sending an SMS.
Current setup.
EB-006-00-6 Multiprogrammer
EB066-00-4 GSM Board (Port C)
LCD Display (Port B)
Pre paid EE Sim card
When I run the current test procedure (http://www.matrixtsl.com/webshop/e-bloc ... board.html) I get the initial sending message, then nothing.
Have I done something wrong? Or is my board not working?
Cheers,
Jack
Re: EB066-00-4 Test Procedure
Hi Jack,
Are you using Flowcode? If so then what version and I'll try and generate you a more specific and up to date example to play with. Also what PIC device is on your EB006 board?
It's doubtful the board has a problem as each one is tested at the factory before dispatch.
JackG
Post by JackG »
PIC in use is: pic16f877A
And yes I can use flowcode if needed.
Here are some Flowcode programs you can try. Let us know how you get on.
GSM_Test.fcfx
(19.72 KiB) Downloaded 272 times
GSM_DialOut.fcfx
(19.28 KiB) Downloaded 288 times
