I want to report for problem with PIC16F877A.
I maked simple programm with PIC16F876A. There is some leds, LCD and buttons. Everything work. I change MC with another, for example PIC16F877A, because have many ports. And surprise: Program work, but LCD not work. I not understand what is reason for this, provided that all conditions are the same.
(Solved) Error with PIC16F877A and LCD
maharadga
- Has thanked: 17 times
- Been thanked: 12 times
- Power supply_PIC16F877A.fcfx
- (32.51 KiB) Downloaded 241 times
- Power supply_PIC16F876A_r.fcfx
- (32.02 KiB) Downloaded 249 times
Re: Error with PIC16F877A
It looks like your program for the 16F877A should be ok. Have you checked that your port B connections to the LCD are correct on the hardware? A quick multimeter connectivity test should confirm if the pins are all connected correctly with no shorts or breaks. Also worth doing a 1 second flasher test if your in doubt the micro is running correctly.
maharadga
Re: Error with PIC16F877A (Solved)
Thank you, Benj.
There is break in wire.
And with the fact that I made other circuits with these cables and they worked and even though I checked everything. But as it says: one more check is never superfluous.
