Question about PIC Voltmeter 0-30V
maharadga
Has thanked: 17 times
Been thanked: 12 times
Post by maharadga »
I maked Voltmeter with PIC16F876A in range 0-30V.
But in range 0-~20V , voltage, displayng on LCD is about ~0,1 V less that real value. In range ~20-30V is Ok.
It's error on ADC or it's my mistake?
Voltmeter_0-30V.fcfx
(18.84 KiB) Downloaded 315 times
Re: Question about PIC Voltmeter 0-30V
Hi maharadga,
Have you tried on real hardware?
I would not have thought it would work at all.
Reason being, for calculations you're using INT variables.
You have got a calculation:
volt = 0.293255 * adc
As volt is an integer you can only multiply and divide by whole numbers only.
For example if
volt = volt * 0.99
then whatever the volt variable starts at, the result will always be 0
So if volt starts off with a value 250 then result will be
250 * 0 = 0
as bytes and intergers are always rounded down and not up.
Try
volt = adc * 10 / 34
martin
maharadga
Post by maharadga »
Hi, medelec35.
Yes, of course I tryed in hardware. Exactly in hardware I see difference 0,1V bellow ~20V.
In your formula " volt = adc * 10 / 34" difference is 0,2V over measured voltage.
Better result is with formula "volt = 0.0300097 * adc" where "volt" is floating point and "adc" is integer.
