Component: Serial EEPROM (24C32)
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Afternoon all,
Looking to use an EEprom in a project. Both Farnell & RS list the 24C16 and 24C32 as No Longer Stocked
A recommended alternative was a 24LCxx in farnell
I have looked at a 24LC64 would the Flowcode component work with this device ?
http://www.microchip.com/wwwproducts/en/24LC64
Has thanked: 481 times
Been thanked: 699 times
Re: Component: Serial EEPROM (24C32)
Hi Steve,
Yes the 24C32 component will work with the 24LC64,
the only limitation will be that simulation will only work for the first 4K bytes.
(The 24C32 component only has a simulation data buffer for the 32Kbits)
Leigh
Chaudhry
Post by Chaudhry »
Hi Leigh, do you have any recommendations for something that doesn't have the 4k bytes limitation? I'm just curious if there's such a product.
You should make use of ExpressVPN privacy and security.
I dont think that we currently have a Flowcode component for serial eeprom bigger than the 24C32,
So the Flowcode simulation is limited to 4K bytes of that device.
However, due to the way the device is addressed, the 24C32 component can be used to create on target code for larger devices, such as the 24LC64
