Adjustable CANBUS speed
Please add any feature requests for Flowcode version 7 here
celebriums
Has thanked: 71 times
Been thanked: 33 times
Post by celebriums »
Hi All
Can there be more options to adjust the internal CANBUS speed? For example; 25, 50 kb/s or manually adjustable
These low speeds are used in the lift industry.
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
Re: Adjustable CANBUS speed
Hi Sadik,
I've had a quick go for you at adding the new baud rates you suggested.
cal_can.fcpx
(10.07 KiB) Downloaded 281 times
CAN.fcpx
(25.68 KiB) Downloaded 313 times
Simply copy the attached files into your "Flowcode 7/Components" folder and restart Flowcode and the new rates should now be available in the drop down list when selecting an internal CAN channel.
Let us know how you get on with them.
celebriums
Hi Benj
I hope your fine. Thank you very much for your quick support.
I will share the results with you once you have.
Sincerely Regards
Sadık SUME
