Infrared Array Sensor
Please add any feature requests for Flowcode version 7 here
celebriums
Has thanked: 71 times
Been thanked: 33 times
Post by celebriums »
Hi All
I am working on this Infrared Array Sensors. I have two different products. Can you add these products as a component in the FLOWCODE library?
Thanks of advance.
AMG88XX Infrared Array Sensor (8x8)
DataSheet:
https://industrial.panasonic.com/cdbs/w ... 000C53.pdf
Application:
https://www.adafruit.com/product/3538
Library:
https://www.arduinolibraries.info/libra ... xx-library
Melexis Infrared Array Sensor (32x24)
https://www.melexis.com/-/media/files/d ... elexis.pdf
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
Re: Infrared Array Sensor
Hi Sadik,
The first one looks simple enough. Not looked at the second one yet but certainly interesting sensors!
celebriums
Hi Benj
I hope your fine. Flowcode 6 has been mentioned about this, but I guess it has not reached the end
viewtopic.php?f=54&t=19916&p=87241&hilit=amg#p87241
Melexis and Omron have been working on this for a long time. The prices are a little pricey but they are cheap soon.
Omron products (16x16)
https://www.omron.com/media/press/2013/05/e0529.html
http://symmetron.ru/suppliers/lighting/ ... 20MEMS.pdf
http://omronfs.omron.com/en_US/ecb/prod ... en-d6t.pdf
Sincerely Regards
Sadık SUME
Here's a go at the 8x8 sensor. It uses a 64 float array so requires a fairly large amount of RAM, (64 x 4 = 256 Bytes). This is based on the Adafruit library but is likely overkill, we might be able to reduce this in future.
Copy the file to your Flowcode 7/Components directory and restart Flowcode and it should appear in the Sensors category.
AMG88xx.fcpx
(5.08 KiB) Downloaded 330 times
Let us know how you get on.
