PIC32MM ADC
MelvinA
PIC32MM ADC
Post by MelvinA »
Hello. Can you please help with the ADC on a PIC32MM. Any getbyte, getint or getvoltage component makro is not working.
The program stops there. I downloaded the sample / demo program called ADCByte.fcfx. This program runs fine on 8-bit devices like the PIC18F4620.
I have been able to run other sample project on the PIC32MM just fine
Re: PIC32MM ADC
Thanks for letting us know. I have had a look and think I may have found the problem.
Firstly please can you update the PIC32MM definition files. The archive below needs to be extracted into the "Flowcode 7/FCD/PIC32" folder overwriting the files there.
PIC32.zip
(47.95 KiB) Downloaded 194 times
Next you also need to copy the file below into your "Flowcode 7/CAL/PIC32" folder.
PIC32BIT_CAL_ADC.c
(16.64 KiB) Downloaded 214 times
Restart Flowcode if you have it open and hopefully the ADC will now work as expected.
Let us know how you get on.
