STM32F334 and High Speed PWM
An area to discuss ARM specific problems and examples
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hello!
Is it possible to implement the STM32F334 HRTIM PWM library?
How do I call the HAL library?
Linked Document Chapter 2.1, A Single PWM Generation Example.
HRTIM cookbook:http://www.st.com/resource/en/applicati ... 121475.pdf
Has thanked: 481 times
Been thanked: 699 times
Re: STM32F334 and High Speed PWM
The stm32f3xx_hal_hrtim.h header file is linked into the Flowcode build, so you should be able to call the HAL functions from a C icon
STibor
Post by STibor »
Can you help me with an example?
Thanks!
Here I just did a copy'n'paste from the HRTIM cookbook, not that I'm confirming that it works, I've never tried it, but the C code is valid ...
STibor
Post by STibor »
The empty project is also bad.
empty_stm32f334_nucleo.msg.txt
(57.19 KiB) Downloaded 655 times
empty_stm32f334_nucleo.fcfx
(6.37 KiB) Downloaded 557 times
Attached update to go into your Flowcode installation FCD\ARM\ directory.
32F334Nucleo64.fcdx
(28.91 KiB) Downloaded 535 times
STibor
Post by STibor »
I've created a demo program for HRTIM PWM.
There may be a terrible part of the code. (spaghetti code): D
I do not really understand C programming.
https://youtu.be/b0M7hRunN7Y
stm32f334_nucleo_hrtim_demo_DM00121475.fcfx
(23.29 KiB) Downloaded 575 times
Thanks for sharing :D
chad
Has thanked: 27 times
Been thanked: 33 times
Post by chad »
Hi thanks for digging into this. I am going to be playing with pwm on the 446re chip. This is a big help.
Chad
